My battery is leaking acid i think or so.It has a small crack enough to leak located next to the two positive and negative battery terminal...so since i used and put those felt pads there...the pads are just absorbing those leaks and getting very wet and soggy now.Should i replace the battery or not because the battery still work fines its just the leaking at the top next to each of those terminal.
And the battery i think is from 9/2007.almost 3 years.
If so change...should i just go with a duralast one?
