Coolant Temperature Sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2010, 11:23 AM   #1 (permalink)
View Chivas1's Photo Gallery
Hi, Im new here and I am having trouble locating the Coolant Temperature Sensor on a 2000 Toyota Corolla (manual transmission). I got the P0115 code and have purchased the sensor but I cant locate it to change it. Can anyone please tell me where its located and if you any images that show its location.
Thanks in advance
Chivas1 is offline   Reply With Quote
Old 03-01-2010, 11:57 AM   #2 (permalink)
View hungt1999's Photo Gallery
This is from Autozone website
1. Disconnect the air/fuel ratio sensor connector.
2. Remove the four bolts that retains the exhaust manifold heat insulator.
3. Remove the five nuts and then the exhaust manifold
4. To prevent possible damage, remove the gasket from the cylinder head.
5. Using Special Tool 09817-33190, remove the Engine Coolant Temperature Sensor.
To install:
1. Using Special Tool 09817-33190, replace the Engine Coolant Temperature Sensor.
2. Replace the cylinder head gasket.
3. Replace the exhaust manifold and the five retaining nuts.
4. Replace the exhaust manifold heat insulator and the four bolts.
5. Connect the air/fuel ratio sensor connector.
hungt1999 is offline   Reply With Quote
Old 03-01-2010, 12:38 PM   #3 (permalink)
is it right by the engine yellow oil disptick? sorry I just haven't worked on these cars at all, its my father in-laws car.
http://farm3.static.flickr.com/2562/...bcf3a346d0.jpg
Old 03-01-2010, 02:37 PM   #4 (permalink)
View rgurleyjr's Photo Gallery
My understanding is that the sensor is on the drivers side of the head, and the only way to get it out is with a deep well socket, 19mm I think. Not sure what the first guy was thinking?
rgurleyjr is offline   Reply With Quote
Old 03-01-2010, 03:08 PM   #5 (permalink)
Thanks, I will look for it when I get home.
