I nor Toyotanation is not responsible if you mess up your car doing this simple install. Do at your own RISK
Tools needed:
pull that wire off for room and use a 10mm socket on a 3/8 ratchet on the two bolts in the back of the tensioner. after that use a flathead screwdriver and try to pry the tensioner out. for me it came part way and i had to use a hammer with the screwdriver as a punch to get it all the way out.
install the new tensioner as mentioned (clip on belt side of engine.) with a little bit of effort it should go in. put the two bolts back in and put the wire back on.
NOTE: AFTER THAT IS DONE USE A 10MM WRENCH ON THE ALTERNATOR AND TURN THE ENGINE COUNTERCLOCKWISE. IF EVERYTHING IS DONE CORRECTLY THE TENSIONER SHOULD POP OUT IN THE ENGINE AND YOUR'RE GOOD TO GO. i suggest checking your oil before you start your engine. i lost a fair amount. Good luck
