MAF sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2010, 07:40 PM   #1 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
MAF sensor
Hey i noticed that my maf sensor's thermostat thingy thats on the side where you can see....i notice that one side is bright and shiny while the other side is rusty and dirty covered up.Will that affect anything?
btw how would you know when your maf sensor is dirty...clean it once in a while?
ilovecorollale is offline   Reply With Quote
Old 03-10-2010, 07:51 PM   #2 (permalink)
Big T Dizzle fo Rizzle
BigTDogg (MA)'s Avatar
View BigTDogg (MA)'s Photo Gallery
I clean mine every oil change, when I clean my K&N air filter.
My Vehicles:
2001 Toyota Corolla LE - EBC Ultimax Rotors, HPS pads, Goodridge stainless lines, K&N drop in filter, Magnaflow cat and Exhaust, KYB GR-2, Tein H-Techs
1990 Nissan 300ZX Twin Turbo - More mods than Lindsay Lohan has freckles
BigTDogg (MA) is offline   Reply With Quote
Old 03-10-2010, 10:31 PM   #3 (permalink)
Bdub215's Avatar
Gameroom cash: $316765
View Bdub215's Photo Gallery
^ dam thats OCD.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 03-10-2010, 11:06 PM   #4 (permalink)
Gameroom cash: $120800
View Milky's Photo Gallery
yes, clean the maf. it can cause some problems down the line. if you use a pre oiled filter, like a k&n, then you should clean it about the same time you clean your filter. this is because the oil from the filter can get on the maf wire causing it to read incorrectly. however, if you run a dry filter, like the aem dryflo, then you dont need to clean the maf but once every few years (2-4) since it will pick up dirt at a lesser rate because of the oil free filter.
Milky is offline   Reply With Quote
Old 03-11-2010, 03:45 PM   #5 (permalink)
Originally Posted by Bdub215 View Post
^ dam thats OCD.
You think that's OCD, you should see my other car
But I just include it as a part of the oil change job. I do my own oil changes, so while the oil drains, I take out the K&N and clean it off. Then I clean the MAF, shake it dry, then reinstall it. Fill the oil and I'm good. While the K&N dries, I use a regular paper air filter for a day, then switch back to the K&N whenever it's convenient in the next day or two.
My Vehicles:
Old 03-13-2010, 08:28 PM   #6 (permalink)
Does it has to be carb choke cleaner or it can be any cleaner like brake cleaner too for instance?
Old 03-13-2010, 08:49 PM   #7 (permalink)
ロンリードライバー
Gameroom cash: $224935
View all2baka's Photo Gallery
It's a sensor, I'd be using MAF Cleaner
all2baka is offline   Reply With Quote
