Do MAP sensors (such as in my 99 Prizm) ever need to be cleaned? (pics included) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2010, 07:18 PM   #1 (permalink)
View Mithridates's Photo Gallery
Question Do MAP sensors (such as in my 99 Prizm) ever need to be cleaned? (pics included)
Some cars have a Mass Air Flow (MAF) Sensor. Mine has a Manifold Absolute Pressure (MAP) Sensor. I have heard that MAF sensors can be cleaned with a spray can of CRC MAF Sensor cleaner, as part of routine maintenance. I was wondering if MAP sensors either can or need to be cleaned in a similar manner. Here's a close-up of the part:
Here's a pic of the part installed in my car:
Mithridates is offline   Reply With Quote
Old 03-14-2010, 07:29 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
not really, only time it could need to be cleaned would be if the port on it became clogged. its just a pressure transducer and has a small hole in it thats open to the manifold to read pressure changes.
The Following User Says Thank You to Bitter For This Useful Post:
Mithridates (03-14-2010)
Old 05-24-2010, 07:48 PM   #3 (permalink)
View turbo_slug's Photo Gallery
i was hunting around the engine bay of my dad's corolla but couldn't find a maf sensor. i did however find a sensor that looked like a map sensor. i then did a search and came across this thread...so which cars had a map and which ones have a maf? why did toyota switch between the two?
turbo_slug is offline   Reply With Quote
Old 05-25-2010, 11:56 PM   #4 (permalink)
Gameroom cash: $120800
View Milky's Photo Gallery
98-99 has map sensors, the 00-02 has maf. maf is much more precise in its measurements, so it is possible to keep the fuel mixtures closer to an optimum balance for driveability and fuel economy. plus toyota also swapped to vvt-i and coil on plugs at the same time.
Milky is offline   Reply With Quote
