There were not any cabin air filters in the North American markets for this generation, may not apply to your market.
Assuming that it doesn't have a cabin air filter - does the fan speeds all work, i.e., running though all fan speeds, note an increase in airflow/fan speed? Have you tried other modes, i.e., recirc, defrost, vent, etc.? Can you hear the air "flapper" move when you change modes - should be quite obvious when you change where the air is directed? Made sure that the vents are switched off - here the vents have a manual switch on/off on the side-most vents?
Chances are - the blower is just buggered up with all sorts of debris - leaves, twigs, dust, etc. and not able to move as much air as it should. I know when I cleaned mine out - I was shocked by how dirty it got.
