Transaxle should be up to normal operating temperature - just plan on checking the fluid level after your usual drive/commute.
- Park on level ground
- Car in park, engine running
- Level should be close to the "Hot" mark (between the two notches is OK, but be better the closer it is to the upper mark without going significantly over the upper mark).
- If too low, use a small funnel and refill through the transaxle dipstick hole - guard against overfilling the transaxle.
