Brake Pedal Travel Question on our corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2010, 12:52 AM   #1 (permalink)
View Corolla02's Photo Gallery
Hey guys,
For the past couple year's the corolla in our family has been great in every department except for the brakes. The brake pedals require slight travel before the car starts braking. I know you should feel the brakes immediately with a slight tap on the pedal but ours require some travel before that happens. We had a mechanic checked it out today and he said the brake pads and rotors are all very good. He also tested the brakes and said it also has some travel in the pedals. The only answer he can give us is "thats just how the car is" and i highly doubt thats the case.
Wondering if you guys have any advice as to what to do? Top off brake fluid or have it flushed? Some say brake travel has nothing to do with the pads and rotors so i am aware of that.
- Thanks!
btw, just got the car back from the body shop and its in perfect shape!
2002 Toyota Corolla ce - stockkk!
Corolla02 is offline   Reply With Quote
Old 03-28-2010, 10:11 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
it could be that the rear drums are a little out of adjustment, there's also an adjustment on the master cylinder rod, or a small bit of air in the system can cause a low pedal also.
Old 03-28-2010, 11:21 AM   #3 (permalink)
View mr1114's Photo Gallery
How much does the parking brake lever travel? If its a lot, then the rear brakes need adjustment, and this will also affect the travel of the brake pedal. The parking brake on my car requires about two "clicks" to become fully engaged.
2006 Corolla S - sold
2003 Solara SLE - sold
2000 Corolla LE - sold
mr1114 is offline   Reply With Quote
Old 03-28-2010, 11:06 PM   #4 (permalink)
Thanks for the input guys.
Im thinking of getting the brake lines checked and maybe bleed the brakes. Does anyone know how much i should be looking to pay for that?
I checked the fluid levels today and its right in the middle of Max and Min. Should i top it off?
- Thanks
