Tranny overfilled what to do? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2010, 04:16 PM   #1 (permalink)
View Sonix's Photo Gallery
A mechanic accidentally overfilled my trany in a 98 rolla by about 1 inch over hot when hot, how urgent is it? And whats easier the drain plug or the transmission cooler line? Pics of both would be nice because I would rather do it myself. In an older rolla I had the drain was on the bottom of the pan right in front with a big...about 10-14mm bolt.
Thanks
Sonix is online now   Reply With Quote
Old 03-28-2010, 06:04 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
use a tube to suck some out the fill tube.
Old 03-28-2010, 06:23 PM   #3 (permalink)
Thanks, I'll start my quest to find the right diameter tubing tomorrow to just get it done. But I also wanted to do a drain and fill. Nothing going on wrong though.
On a lighter note, my valve cover gasket oil leak was bigger than I knew, bottom dry now and buying oil isn't burning a hole in my pocket.
Old 03-28-2010, 08:41 PM   #4 (permalink)
View mr1114's Photo Gallery
The drain plug has to be the easiest way I would think
2006 Corolla S - sold
2003 Solara SLE - sold
2000 Corolla LE - sold
mr1114 is offline   Reply With Quote
Old 03-29-2010, 08:01 AM   #5 (permalink)
DjiNN's Avatar
View DjiNN's Photo Gallery
If he used the drain plug he would have to stop mid way somehow. Unless he told the mechanic that he got it done at to drain and refill with new fluid.
Subaru Impreza 2.5i Premium Satin White
DjiNN is offline   Reply With Quote
Old 03-29-2010, 08:33 AM   #6 (permalink)
Pretty easy to screw in a drain plug while the fluid is still draining. At least to me.
Old 03-29-2010, 08:38 AM   #7 (permalink)
Acording to the manuel only 2.7~ quarts will fall out, so I'm going to just open it up and let it fall. I hope my tranny doesn't get used to a steady diet of new fluid though!
Old 03-29-2010, 09:27 AM   #8 (permalink)
Gearhead
Gameroom cash: $196215
You can drain it from the plug, but it could get messy. Just holding the plug without removing it will drain part of the fluid (probably run down your arm while your at it).
Sucking it out the fill tube is the least headache - especially if you have a vacuum tool, like a Mighty Vac or similar. That way you can remove the exact amount of overfill, with no chance to mess up or top off.
