Advice Needed For Ball Joint Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2010, 03:18 PM   #1 (permalink)
View jbroda's Photo Gallery
Please, advise on the replacement procedure of the front lower ball joints on a 1999 Corolla LE.
I read the Toyota's repair manual procedure and it asks to remove the front axle hub.
Can I get away without removing the hub?
Thanks!
jbroda is offline   Reply With Quote
Old 03-29-2010, 03:46 PM   #2 (permalink)
Toyota Tech in training!
View Downhillzze110's Photo Gallery
to answer your question: no you do not need to remove the axle carrier.
all you need to do is take off the nuts and bolts (its got one of one and two of the other), break it loose, and remove it.
you may want to reread your manual as every repair procedure i've read never mentioned removing the axle carrier to remove the ball-joints. now you DO have to remove the ball joints to remove the axle carrier, but thats a horse of a different color
before you ask a 'how do i...' question answer this for me. do you own a repair manual for it? have you searched the forum for a similar issue?
SEARCH THE FORUM BEFORE YOU POST!
Downhillzze110 is offline   Reply With Quote
