Front Axle: Proper installation advice? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2010, 04:37 PM   #1 (permalink)
randini667's Avatar
View randini667's Photo Gallery
I repacked my front axles. They look and feel good.
I see they are designed to be somewhat adjustable, at least look like adjustable ones I've worked on before (using the axle nut torque as the preload). Anyways my question is...
Is there a proper way to adjust/install the front bearings and hubs?
Thanks!
-Randy
randini667 is offline   Reply With Quote
Old 04-14-2010, 12:29 PM   #2 (permalink)
Fergifruitchew's Avatar
View Fergifruitchew's Photo Gallery
If you havnt figured it out yet, i would guess noone on here really knows...all i can say it go get yourself either a haynes or chilton manual for this generation of corolla and it will tell you everything you need.
Fergifruitchew is offline   Reply With Quote
Old 04-14-2010, 04:16 PM   #3 (permalink)
Gearhead
Gameroom cash: $196215
Old school - load the nut, wiggle the hub and note if it moves at all or not, should be no play. That's how I do it on all my older cars.
Or to do it right - need a dial indicator. I believe the specs say the allowable deviation (backlash) is 0.05mm (0.0020") allowable in and out near the center of the hub, 0.07mm (0.0028") allowable near the edge of the hub.
Old 04-15-2010, 05:27 AM   #4 (permalink)
View TrackGeeks's Photo Gallery
Thanks!
-Randy
The hub bearings are not tapered as they would be on a RWD car. The torque on the axle nut does not add any preload to the bearings.
When installing the axle in the hub you should install the spindle nut and torque it to 166 ft/lbs (per the factory manual).
TrackGeeks is offline   Reply With Quote
Old 04-16-2010, 08:44 PM   #5 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
when installing a NEW wheel bearing its a good idea to run the axle nut down tight as the gun will go once to ensure its all pulled together, then back it off and torque correctly. I've seen problems with aftermarket hub bearings 'coming apart' shortly after installation due to them not being 100% pressed together when they're made. running the nut in will pull them 100% together and negate any manufacturing problems like that.
