Originally Posted by Salty_Dog
How so?
shorter runners for better mid to top end, larger throttle body, bigger plenum, less turbulent design (no ginormous welds in the runners), cooler air intake temps due to the high temp plastic not heat soaking like the aluminum one will.
its all around better. the only problem with swapping one on to an 8th gen, is it will slightly kink the upper rad hose. does not cut off flow at all. i ran like this all summer last year, in 90+ weather with ac on most of the time. never once went past normal operating temp. i did swap to a different radiator just because it bugged me.
