MTXR,
I am doing well! How are you?
I have a very similar issue as well. My dad has a 2000 corolla, with the same issue as Randy. I on the other hand have automatic windows in my prizm. What I have found is that the noise doesn't come from the window seals, but rather the door seals.
If you sit in the drivers seat, and stick your hand up in the top/back corner of where the door closes, you'll find it is kind of a weird design. There is maybe 3 inches of material from the door seal there. I'm actually in the process of trying to fix this. My solution is probably going to buy a thicker, black, sponge-like rubber, and just put it over the existing rubber seal. It will make the door close tighter hopefully eliminating the noise.
...I hear you though about it. I drive to school, and when I get on the freeway, it really sucks.......
