legal or illegal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2010, 09:43 PM   #1 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
legal or illegal
Is having yellow corners allowed in oroville california?Does anybody know...there was way too much info when i research so i was confused.
thanks
ilovecorollale is offline   Reply With Quote
Old 04-08-2010, 06:32 PM   #2 (permalink)
~Veer~'s Avatar
View ~Veer~'s Photo Gallery
I don't see why not :S
~Veer~ is offline   Reply With Quote
Old 04-08-2010, 10:14 PM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
check your local laws, you live there...we don't.
Old 04-08-2010, 11:23 PM   #4 (permalink)
there;s too many local laws here and there and i dont know so whoever lives in ca please help.
Old 04-09-2010, 09:27 AM   #5 (permalink)
'95 Previa S/C AWD Driver
AlaricD's Avatar
Gameroom cash: $150452
View AlaricD's Photo Gallery
From California Department of Motor Vehicles Vehicle Code
Side, Cowl, or Fender Lamps
25106. (a) Any motor vehicle may be equipped with lighted white or amber cowl or fender lamps on the front. Any vehicle may be equipped with not more than one amber side lamp on each side near the front, nor more than one red side lamp on each side near the rear. The light source of each such lamp shall not exceed four standard candlepower.
(b) Lamps meeting requirements established by the department for side-marker or combination clearance and side-marker lamps may be installed on the sides of vehicles at any location, but any lamp installed within 24 inches of the rear of the vehicle shall be red, and any lamp installed at any other location shall be amber.
Amended Ch. 723, Stats. 1979. Effective January 1, 1980.
and
Color of Lamps and Reflectors
25950. This section applies to the color of lamps and to any reflector exhibiting or reflecting perceptible light of 0.05 candela or more per foot-candle of incident illumination. Unless provided otherwise, the color of lamps and reflectors upon a vehicle shall be as follows:
(a) The emitted light from all lamps and the reflected light from all reflectors, visible from in front of a vehicle, shall be white or yellow, except as follows:
(1) Rear side marker lamps required by Section 25100 may show red to the front.
(2) The color of foglamps described in Section 24403 may be in the color spectrum from white to yellow.
(3) An illuminating device, as permitted under Section 24255, shall emit radiation predominantly in the infrared region of the electromagnetic spectrum. Any incidental visible light projecting to the front of the vehicle shall be predominantly yellow to white. Any incidental visible light projecting to the rear of the vehicle shall be predominantly red. Any incidental visible light from an illuminating device, as permitted under Section 24255, shall not resemble any other required or permitted lighting device or official traffic control device.
(b) The emitted light from all lamps and the reflected light from all reflectors, visible from the rear of a vehicle, shall be red except as follows:
(1) Stoplamps on vehicles manufactured before January 1, 1979, may show yellow to the rear.
(2) Turn signal lamps may show yellow to the rear.
(3) Front side marker lamps required by Section 25100 may show yellow to the rear.
(4) Backup lamps shall show white to the rear.
(5) The rearward facing portion of a front-mounted double-faced turn signal lamp may show amber to the rear while the headlamps or parking lamps are lighted, if the intensity of the light emitted is not greater than the parking lamps and the turn signal function is not impaired.
(6) A reflector meeting the requirements of and installed in accordance with Section 24611 shall be red or white, or both.
(c) All lamps and reflectors visible from the front, sides, or rear of a vehicle, except headlamps, may have any unlighted color, provided the emitted light from all lamps or reflected light from all reflectors complies with the required color. Except for backup lamps, the entire effective projected luminous area of lamps visible from the rear or mounted on the sides near the rear of a vehicle shall be covered by an inner lens of the required color when the unlighted color differs from the required emitted light color. Taillamps, stoplamps, and turn signal lamps that are visible to the rear may be white when unlighted on vehicles manufactured before January 1, 1974.
Amended Sec. 38, Ch. 766, Stats. 1995. Effective January 1, 1996.
Amended Sec. 4, Ch. 198, Stats. 2004. Effective January 1, 2005.
Looks like you're in good stead (besides, those standards did not appear to conflict with the FMVSS). Check with your lawyer or with the California Highway Patrol to ensure you have the correct information. Get any information *in writing*.
AlaricD is offline   Reply With Quote
Old 04-09-2010, 09:38 AM   #6 (permalink)
Bingo's Avatar
View Bingo's Photo Gallery
I think the cops have bigger problems than lights...Oroville being the Meth Capital of CA.
Bingo is offline   Reply With Quote
Old 04-09-2010, 10:48 AM   #7 (permalink)
Oh i see sounds good to me...thanks for the info and i did read past that info when i research but want to check with you guys.
Any other info...spit it out.
Old 04-11-2010, 10:24 AM   #8 (permalink)
on full afterburner
Gameroom cash: $1344797
If you want to make sure, just go to a local donut shop and ask the popo sitting there.
They should be able to tell you.
Laws change all the time.
Old 04-11-2010, 12:34 PM   #9 (permalink)
AlaricD's Avatar
And sometimes the police are the last to know of those changes. If you must ask one, get the question and his response *in writing*, so that way if he told you wrong, you have some defense (especially if you can reasonably assert that his answer was maliciously wrong).
