Originally Posted by Milky
DDMtuning.com plug and play hid kits with lifetime warranty 39.00 + shipping. they even include the h4 glare shields. just dont order anything over 6k or you will have really bad glare.
Those are junk, and illegal, pure and simple.
The reflector housing is designed for a straight filament; HID bulbs produce an arc, which by definition is curved. The beam pattern will be way off and cannot be adjusted for by reaiming.
Originally Posted by toyotaman11
My only concern is getting pulled over. I live in rural Illinois, so I am not sure how the cop response will be. I am thinking about going 35w and either 4500k or 6000k. Not sure which will be less conspicuous?
The maximum legal nominal wattage for HIDs is 35, the legal nominal color temperature range is 4100-4250K.
4500 would be less conspicuous and generate less glare for you and other drivers. Still, HID kits installed in assemblies designed for filament bulbs are unsafe and illegal.
Originally Posted by MFCC08
Wow this is a really great price and bargain!!! So if we got the 55w, we wouldn't need any special hook ups or anything would we??
Again, the maximum legal nominal wattage for HIDs is 35.
Is it really a bargain to get ticketed or your vehicle impounded due to illegal headlight modifications?
As Bitter pointed out, there are better legal options.
If you have headlights with the 9003/H4/HB2 bulbs (1998-2000, combined low/high beam functions) then get
these. If you have separate low/high beam lights (2001+), then get these
9006 bulbs for the low beams, and these
9011 bulbs for the high beams (requires a base modification).
Also, if your night vision is that poor, there are things you can do to help with that. One technique is to wear very dark sunglasses indoors for about 20 or 30 minutes before going out to your car, removing them only when you're ready to start the car (careful walking out to it in the dark!) to help your eyes adjust to the darkness.
Also, if you are nearsighted, wear corrective lenses, and avoid high color temperature lights on your car because blue light already focuses in front of the retina-- it's even worse for those already nearsighted. Talk to your optometrist or an opthalmogist for additional ideas and testing. Poor night vision could be the sign of other problems.
One last thing: Make sure the lenses are clean and
clear, and that the lights are
aimed properly.
