Have seen reports of good results with Valvoline Maxlife motor oil on 1ZZ-FE that tend to use oil.
Also depends on how the oil is being use. Stuck piston rings are most likely, with the burn rate that you are seeing (1 quart every 600-800 miles), might get lucky with something like AutoRX or even seafoam.
Have you done a compression test / leak down test to see where you stand?
As mentioned above, additives will not fix the root issue, but they could extended the time you have to work with.
