2ZZ Oil Filter for 2001 Corolla 1ZZ-FE ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2010, 10:33 AM   #1 (permalink)
View morkys's Photo Gallery
Buying oil and filter today. I thought I saw somewhere that some folks use the 2ZZ-GE oil filter on their 1ZZ-FE engines. Is this ok? Does it provide better flow and/or better filtering of the oil?
thanks,
morkys is offline   Reply With Quote
Old 04-11-2010, 10:55 AM   #2 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
Same flow, just a taller filter by 1/4 inch. This give you more filter media per square inch.
The best part, its the same price.
If it actually matters and does something, that im not sure of.
SCCA First Place 10/25/09. NST
Crowbar911 is offline   Reply With Quote
Old 04-11-2010, 11:06 AM   #3 (permalink)
on full afterburner
Gameroom cash: $1344797
If it fits and it's the same price, use it.
You'll be able to run a longer oil change interval.
Old 04-11-2010, 02:05 PM   #4 (permalink)
Ok. Which year and model oil filter do I get? While at Canadian Tire today, I tried comparing an 02 Celica GTS oil filter to my 01 Corolla CE and the rubber o-ring's had different diameters. Did I chose the wrong year and model car? I assumed the 02 Celica GTS has a 2ZZ engine. Perhaps I need to only look at the 03 or later XRS Corolla / Matrix?
What year and model of car should I look for an oil filter for that will fit my 01 Corolla (Corolla XRS, Matrix XRS, Celica GTS or GT?) ?
We have NAPA / UAP , Princess Auto etc and other auto parts stores here besides Canadian Tire.
thanks...
Old 04-11-2010, 06:48 PM   #5 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
Been using YZZF1 for a few years. I can now run my oil for longer than a year. Hell I even use the same thing for the 5S Camry.
thanks...
Anything that can go into a 05 Corolla XRS, 03 Matrix XRS or 00 Celica GT-S.
Anything that cross with PH7317.
Anything that cross with 90915-YZZF1. Or just buy this thing from a Toyota dealer. No ecotaxontax last I checked.
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 04-16-2010, 03:58 PM   #6 (permalink)
View i8urvtec's Photo Gallery
I got the wrong one too I got one of a 02 gts ph3614 ooops
i8urvtec is offline   Reply With Quote
Old 04-16-2010, 05:37 PM   #7 (permalink)
I'll try to pick one up this weekend and report back.
Old 04-16-2010, 08:40 PM   #8 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
iirc the 2ZZ filter has a higher bypass pressure (oil pressure and rpm go together somewhat), so on a 1ZZ you'll have full filtration more of the time than you would with a 1ZZ filter. this is to cope with the 2ZZ being wound out alot and running higher RPM's, so this works to your 1ZZ's advantage.
Old 04-16-2010, 10:26 PM   #9 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
I thought the filter number was hp-1003...that would fit those 8th gen corolla and those 2000 celicas and up.
Never mind.
Here's a list i found for you guys...hope it works...?
2zzge oil filters:
Fram PH4967, PH2951, PH4386, PH5166; Fram Toughguard TG496; Purolator L14477 (3.52" long); Purolator Proline PPL14477; Purolator L14476 (2.93" long); Toyota 90915-03001 or 90915-10004; Mobil M1-103; Wix 51396, 51366, 51394, 51395, 51625; K&N HP-1003 or HP-2009; AC PF10001, PF10002, PF1233, PF1234, PF13011, PF2052, PF53J00; Motorcraft EFL89, FL271, FL782, FL836, FL840
Heres a web that talks of the same thing...http://www.9thgencorolla.com/forum/a...p?t-82021.html
ilovecorollale is offline   Reply With Quote
Old 05-23-2010, 09:36 PM   #10 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1339866
iTrader Score: 7 reviews
My parts guy at Toyota has always given me the longer filter. The same Toyota filter fits my 94 Corolla DX, 89 MR2 S/C, & 07 Matrix XR.
ROTM November 2011 Winner!
SuperchargedMR2 is offline   Reply With Quote
Old 06-01-2010, 05:36 PM   #11 (permalink)
Prizm LSi Driver
View ChargerGL's Photo Gallery
Anyone use the TRD filter? PTR43-33010
ChargerGL is offline   Reply With Quote
Old 09-18-2010, 07:22 AM   #12 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
sorry to bring up this old thread but does anyone know if the mz filters will fit? i have a lot of them for my mz and my father-in-law has a zz in his rolla i was gonna put one of mine on but will it fit? i know the mz have a wider filter (wount fit the az tried) and a small bit taller and the gasket seems to be larger.
^ and leaving it that way!
Old 09-18-2010, 08:43 AM   #13 (permalink)
Bitter's Avatar
cross reference the numbers/check the gasket diameter and thread pitch.
Old 06-10-2011, 11:14 AM   #14 (permalink)
View GREENPUS's Photo Gallery
The PH7317 has M20x1.5 thread
The YZZF1 has 3/4-16 thread.
I guess that's close enough....
GREENPUS is offline   Reply With Quote
Old 06-12-2011, 08:23 PM   #15 (permalink)
Beware of pigs
Buurin's Avatar
I wouldn't settle for anything less than exact match.
Buy my parts
Buy my other stuff
