Rear Vibration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2010, 12:38 AM   #1 (permalink)
View 1_grendal's Photo Gallery
Rear Vibration (Pics Added 1st Post)
I have a 2002 Corolla. The rear end starts to shake my teeth out at around 55mpg and continues until I reach 70/75mph; it gets worst the faster I accelerate.
I have:
Replaced the tires
Rotated the rims/tires
Replaced/swooped out/borrowed the tires/rims from a 2001 corolla (sisters car)
Check the rear bearings (seem good no play, spins free)
Replaced the rear struts.
Check the rear bushings (seem ok)
Any advice would be welcomed
Thanks
Ya finally got it fixed
In the process this problem forced me to replace 4 extremely bad (not working any longer) struts/shocks.
I Thoroughly check out my bushings (look good so far)
I ended up doing a full service, in short: tranny, plugs, coolant, stat, hoses, belt among other things.
i hate trying to find the source of vibration issues almost as bad as finding water leaks
Anyway here are the pics to the right side axel replacement.
Once i had the axel out i found the joint had worn. i am doing an educated guess but i believe due to the worn joint the axel was out of balance causing the car to shake.
once i took the car for a test drive i found that all the shaking in the steering wheel went away .
Here are the pics
1_grendal is offline   Reply With Quote
Old 04-19-2010, 01:26 AM   #2 (permalink)
Gameroom cash: $120800
View Milky's Photo Gallery
have you checked the front ball joints? or the tie rod ends? are you 100% sure that its coming from the rear? does the steering wheel shake when the vibration occurs? if so it is more than likely in the front end.
Milky is offline   Reply With Quote
Old 04-19-2010, 08:35 AM   #3 (permalink)
Milky thanks for the input, the vibration is/seems in the set, the steering wheel is not shacking.
At this point i am open to just about anything. i have started to think i need to look at the front end a lot closer i.e. bearings, struts, bushings, CV joint, or i pay a real mechanic to locate the problem.
Old 04-19-2010, 06:36 PM   #4 (permalink)
randini667's Avatar
View randini667's Photo Gallery
Can the rear end suspension be aligned in the corolla/prizm?
randini667 is offline   Reply With Quote
Old 04-19-2010, 11:13 PM   #5 (permalink)
yes. in fact during an alignment it is common to start with the rear first if it is out of spec. this is because the rear alignment spec (in or out) has a direct effect on the front end alignment and a bigger impact on how the car will drive. if the rear end is not trailing perfectly or close to it, behind the front end, then you can create a serious problem depending on how bad it is. the worst being a car that is unstable in the straights and corners. having too much under-steer (resistance to turn / pushes the front end) or having too much over-steer (wants to keep turning / rear end swinging out) can be dangerous even with experienced drivers.
Old 04-25-2010, 01:50 AM   #6 (permalink)
Thanks for your help guys I figured it out
Old 04-26-2010, 10:46 AM   #7 (permalink)
View Chinsan's Photo Gallery
What was the solution?
Chinsan is offline   Reply With Quote
Old 04-26-2010, 05:33 PM   #8 (permalink)
Bumped with solution
see first post
Old 09-08-2010, 10:05 PM   #9 (permalink)
View 2004's Photo Gallery
thanks grendal for the solution & pictures!
2004 is offline   Reply With Quote
Old 09-11-2010, 01:48 AM   #10 (permalink)
View 94PrizmDD's Photo Gallery
So the vibration was coming from the front? Well at least you eliminated every other possible thing that can go wrong in the process.
94PrizmDD is offline   Reply With Quote
