How to disable DRL for 2002 corolla? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2010, 01:27 AM   #1 (permalink)
View gdzswjj's Photo Gallery
Hi, I have done a lot of research from interenet but still can't find out how to disable my 2002 corolla DRL. How can I disable it? Thanks!!!!!
gdzswjj is offline   Reply With Quote
Old 04-21-2010, 02:47 AM   #2 (permalink)
Gameroom cash: $120800
View Milky's Photo Gallery
do you want to keep the twilight feature (auto illuminate) or disable all together. i have my drl's disabled, but still have the twilight feature.
for the twilight feature to work, you need to cut a red-with-yellow-stripe wire from J2, the gray jumper block by the instrument panel fuse block. To find the right wire, unplug J2 and probe between all wires of this color. Two wires are shorted together and goes to the DRL brain. cut the one that has no continuity with any of the other red-with-yellow-stripe wires.
Milky is offline   Reply With Quote
The Following User Says Thank You to Milky For This Useful Post:
gdzswjj (04-22-2010)
Old 04-21-2010, 11:30 AM   #3 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
Don't cut. Instead, once you unplug J2 and have found the wire, take a 1mm flat screwdriver. First lift up the plug's white lock, then stick it into the hole for that wire to pry up a tiny plastic tab. With the tab lifted, pull the wire out. Tape up and secure that wire.
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
The Following User Says Thank You to Buurin For This Useful Post:
Old 04-21-2010, 04:40 PM   #4 (permalink)
I have installed HID lights, so only disable the DRL, the light won't be on automatically when the parking brake is released?
Is there any option that i can do with the DRL relay to disable the it instead of the DRL brain?
Old 04-22-2010, 02:30 PM   #5 (permalink)
Beware of pigs
Buurin's Avatar
Here is my answer to gdzswjj in PM. There's some useful info I thought I should share:
You could disconnect the red/blue (ignition) wire as detailed on some other DIY here, but that kills automatic headlights too as this fools the DRL relay into thinking the car's ignition is never on.
(Milky's) mod removes the DRL output, but as DRL turns on auto headlights through some other circuits, you get to keep that feature.
You can see the gray clip J2 plugs into here:
And the actual J2 here:
Buy my parts
Buy my other stuff
The Following 2 Users Say Thank You to Buurin For This Useful Post:
gdzswjj (04-22-2010), Milky (04-23-2010)
Old 04-23-2010, 12:10 AM   #6 (permalink)
good pics Buurin.
Old 04-26-2010, 07:35 PM   #7 (permalink)
Beware of pigs
Buurin's Avatar
Originally Posted by MistuhVinhie View Post
if i may ask where is the j2? i been trying to find it in your picture but i don't see where
Read again. Gray plug to the side of the fuse panel/junction block. There is only one gray plug attached to it. That is J2.
Buy my parts
Buy my other stuff
Old 04-29-2010, 09:52 PM   #8 (permalink)
Beware of pigs
Buurin's Avatar
Look at Milky's post. You have to do something with it.
Old 05-09-2010, 12:35 AM   #9 (permalink)
new to TN
ExDream's Avatar
Gameroom cash: $119500
View ExDream's Photo Gallery
could u post some pics with the stuff circled :]
ExDream is offline   Reply With Quote
Old 05-11-2010, 06:28 PM   #10 (permalink)
Evil
View evil's Photo Gallery
Canada DRL disable
hey man if ur trying to disable ur DRL theres a very simple way i did the same because i installed HIDs and they were flickering on DRL mode. All u need to do is there are 3 wires going into ur HID blub from the socket one of them is DRL the other one is for headlights and the third one is neutral. U can check which one is for DRL using a multimeter. then simply cut that wire on both sides.
Hope this helps.
evil is offline   Reply With Quote
