Alrighty.
I did the rears. And i hate brakes......
I dont see how you can not open the brake lines in the rear since they go though the strut.
The rears were pretty simple. The only problem that I had is that I didnt put the rear spacer for the strut mount in, and they where making a metal on metal clunk when I go over bumps
After my help went home, I was able to fix one, but I cant get the driver rear strut mount bolt off to put the spacer back.
When I went to bleed the brakes, I was able to do the rears, but rounded off the bleeder valves for the front passenger, and almost for the front driver brakes as well.
I didnt think that the brakes fluid was to bad, Ive never had a problem with stopping. But after 88k miles, the oem fluid was pretty much a dark transmission fluid color. (eww)
I have no air in the system (rears for sure), and the brake fluid never went down into the master cyilnder, and the front brakes were never opened.
The car still locks up the brakes at 30mph to a dead stop, so im ok until I get to a shop tommorrow during my lunch break tommorrow where they are going to bleed the brakes completely (fronts), and do my alignment.
During the test drive, the car handles GREAT! I took some great in the local auto malls test track. (buddies are great!) and the car oversteers. Yes, Oversteer. Im 100% sure about this.
I want to wait until after the alignment if this still happens, but im not sure if I want to keep it, or play around with the rear sway bar adjustments and make it less stiff. (some negative rear camber might be in order too!)
Notes on the pics:
First pic is my buddies camera of me working on friday night/saturday morning.
Second pic is the hieght difference of the oem springs VS eibach prokit. (front)
Third is just me holding a front strut.
Fourth is when you hit your lip with a breaker bar. (sorry for the nose hair)
Total suspension mods:
Ebay strut bar
Hotchkiss sway bars.
Tokico struts
Eibach springs
Ultra Racing Fender Braces
I may be looking into some more ultra racing braces as thats all that I have left I think. The side bars and Front lower bar.
What else?
Ill be updating tommorrow night with the after alightment feelings.
Also, Pics of the lowness will be tommorrow, as its dark out. Im low enough for tire tuck, but im not scraping on anything.
