Originally Posted by fishexpo101
Did you swap the shoes around to back where they were originally? Did you end up replacing the wheel cylinder? Did you grease the contact points where the brake shoes touch the drum's backing plate?
all2baka is right, the trailing (rear) shoe and leading (front) shoe are not interchangeable. It will affect how the brakes "self-energize" or how they bite into the drum. If you hold them side by side, one shoe will have more friction material on it, compared to the other or have the friction material "shifted" on the shoe.
Always a good idea to work on the drums, one at a time - so that you can always go back and reference how things fit together.
yeah the shoes are identical but the friction material is shifted a bit. I dont get how this will affect the performance though. other then that area is not getting friction, but the wheel rotates while stopping anyways, so all the friction will be touching regardless?
the braking performance is still the same as before after i swapped the shoes. The back facing one had alot more material left (the front ones wear alot faster cuz the cars rotation is forward most of the time when braking.)
The master cylinder still seem to be working fine right now, it popped out cause of my dumb mistake of not putting back the drum while pumping. The only difference in the braking right now is that it goes slightly lower. Before i bled the system, the pedal went all the way down, after i bled it, its pretty goood, maybe 10 to 15% more depression required.
