HIDs twitching - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-02-2010, 10:45 PM   #1 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
HIDs twitching
hi i ordered some hids like couple months ago and it has been twitching to present.no clue why.was thinking it is the bulb itself or the ballast or just not enough energy provided.
I did check for loose plugs and wiggly ones but they are all secure tightly.
any clues for me?
thanks
ilovecorollale is offline   Reply With Quote
Old 05-02-2010, 11:33 PM   #2 (permalink)
ロンリードライバー
Gameroom cash: $224935
View all2baka's Photo Gallery
More info would help like what kind/brand kit you bought.
Bad ground point?
all2baka is offline   Reply With Quote
Old 05-03-2010, 05:42 AM   #3 (permalink)
View Highway_maniac's Photo Gallery
twitching HID, hm assume you mean strobing HID?
If so: connect the HID ballast directly to your battery, use a relay to switch the lights on/off. If still strobing, you can try so use a capacitor cable (or DIY: solder an 4700 35V caps before eacht HID balast).
Check your grounds like mentioned, bad ground can also cause strange problems.
ps - Try the following: run the car with lights on. verify the strobing. Trun off the car, leave the ignition in the on posistion. Lights still strobing? Turn off the ignition, remove the key. Lights still strobing?
In my case: engine running or ign. to on: strobing. Turn car off: no strobing. Solved it by connecting the ballasts directly to the battery, and adding 2 caps.
Highway_maniac is offline   Reply With Quote
Old 05-03-2010, 10:59 AM   #4 (permalink)
Bad ground point?
bought it off on ebay by option import or either motorsports partz? i forgot...but it was for like 32 bucks or so.
Old 05-04-2010, 03:37 AM   #5 (permalink)
Gameroom cash: $120800
View Milky's Photo Gallery
is it during the day? did you disable your DRL's? because if it during the day and you didnt disable the DRL's then there is the problem.
Milky is offline   Reply With Quote
Old 05-04-2010, 11:30 AM   #6 (permalink)
Disabled drl a long time ago buddy...and it twitches both at night and day...and only when engine is on and a little twitching when engine is not on w/o key in ignition when you just turn on the light.
Old 05-04-2010, 12:31 PM   #7 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
Does it twitch when you hit the gas?
My normal lights dim a little when im at idle. When I hit the gas they light up a little more.
Maybe they are not getting enough power when at idle?
SCCA First Place 10/25/09. NST
Crowbar911 is offline   Reply With Quote
Old 05-04-2010, 01:03 PM   #8 (permalink)
Nope nothing like yours Crowbar. it just twitches while and during driving and idling....i dont think it twitches when it's cold. I thought maybe it was the light bulb itself?
Old 05-04-2010, 07:57 PM   #9 (permalink)
ロンリードライバー
Explain clearly or give a diagram as to how you hooked it all up.
Old 05-04-2010, 11:10 PM   #10 (permalink)
I just hook it up regularly...no wire cutting connectings...just basically plug and play as everyone says.
Old 05-05-2010, 07:16 AM   #11 (permalink)
Crowbar911's Avatar
So you have the stock 9006 connectors go into the ballast, then wires come out of the ballast and go into the bulb in the headlight?
Maybe a problem with the ballast itself if its always been a problem?
Old 05-05-2010, 04:48 PM   #12 (permalink)
Yeah the way i connected it, is how crowbar mentioned it.
Old 05-05-2010, 10:23 PM   #13 (permalink)
ロンリードライバー
Is there a relay?
Old 05-05-2010, 11:43 PM   #14 (permalink)
i didnt use one when i plugged it.
Old 05-06-2010, 07:34 AM   #15 (permalink)
DjiNN's Avatar
View DjiNN's Photo Gallery
If it is flickering it might be a bad ballast. I've had this happen to me too. After the flicking then it would shut off and i would have to turn on and off my lights in order to get them back on.
Subaru Impreza 2.5i Premium Satin White
DjiNN is offline   Reply With Quote
