98 corola regular oil to synthetic, engine light goes on?
A few weeks ago, i did my normal oil change, on my 98 corolla 3 speed(4 with overdrive), before i was using regular oil, tried to switch to a semi synthetic just to see what it give, cause i know it has some better properties to it then regular oil, such as being more robust, and everything was good, now after a couple of weeks engine goes on, check my fluid levels no wires disconnected engine sounds the same, everything generally looks good, a day later engine light goes off, im like ok, came back went away the same thing, now it back again but i seems to be missing my oil, i don't have blue smoke on my car, at least not that i can see, and there are no oil spots so unless tis all sludged out, is it possible that its become just a burn due to it being semi synthetic instead of using a full synthetic, comments would be nice, ive been told by someone i shouldn't have put 10 w30 semi sin into my car, i find it wouldnt be a problem since it was also the garage that did it
