2001 toyota corolla LE oem steering wheel and airbag upgrade. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2010, 10:05 AM   #1 (permalink)
View quiksy's Photo Gallery
i was wondering if i can upgrade my steering wheel and airbag from my 2001 toyota corolla le with a:
toyota rav 4 all trims steering wheel and airbag 2001-2003
toyota celica all trims oem steering wheel and airbag 2000-2005
toyota mr-2 all trims oem steering wheel and airbag 2000-2005
toyota corolla s oem steering wheel and airbag 2001-2002
toyota corolla all trims oem steering wheel and airbad 2003-2008
if yes, i would like to know if anyone from the forum already have done this upgrade? any pics?
also, i would like to know if only need the new steering wheel and the driver's side airbag, if will fit on my oem 2001 toyota corolla oem airbag plug? or i need to buy another plug to connect the upgraded airbag.
thanks for your help guys
i want this upgrade because i do no like my oem steering wheel, i prefer 3 spoke oem toyota steering wheel, no matter if the color is black instead brown.
quiksy is offline   Reply With Quote
Old 05-15-2010, 03:55 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
The steering wheel from other models should fit directly on, but in terms of the airbag plugs, compare them to the ones seen in these photos from a late model Toyota Yaris (same steering wheel as late model Celicas, MR2s etc). If they're the same, then chances are that they'll be the same across all of the models you mentioned above.
Just a word of warning: Be sure to disconnect the terminals on your battery before taking the airbag out of your car to compare the plugs seen in the photos. After you've disconnected the battery, wait at least 5-minutes. There are two Torx head screws on the rear of the steering wheel. Loosen these and the horn pad/airbag will come off and you can unplug the connectors. Make sure you put the airbag in a safe place, with the Toyota symbol facing upwards.
Here's the pics of the airbag connectors on the Yaris for comparison:
Old 05-17-2010, 08:54 AM   #3 (permalink)
thanks a lot.... i will do that
