okay, my bad about the other post, i was wrong...i was totally thinking about something else i did. the brake booster line is the thing coming out the back of the airbox (coming out toward the firewall. if you follow it, it goes down and onto a metal tube which is connected to the brake system (figures!!), there i a clip on it and it you just squeeze it and pull the hose it should pop off. since mine wouldnt pop off what i did was open the screw of the large hose coming out of the airbox (it pulls air into the engine and its ribbed) and i pulled it off, you can see what im talking about in the top left corner of the first picture. if you put your hand on it you will feel alot of vacuum pressure, and i just poured it dirctly into there slowly. and you know the rest...
the hose out of the back of the airbox
the hose connected to the brake system
