Transmission Fluid Leak (from hose/pipe) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2010, 06:20 PM   #1 (permalink)
View aaronm77's Photo Gallery
On my 99 Corolla the pipe/hose that is right outside the transmission box has rusted and is leaking Transmission Fluid (see in pic).
Can anyone tell me what this/these parts are, and how much it might be to fix it?
aaronm77 is offline   Reply With Quote
Old 05-27-2010, 09:45 PM   #2 (permalink)
View mr1114's Photo Gallery
Looks like the transmission cooler lines.
2006 Corolla S - sold
2003 Solara SLE - sold
2000 Corolla LE - sold
mr1114 is offline   Reply With Quote
Old 05-08-2011, 05:39 PM   #3 (permalink)
Turk
View blumonster's Photo Gallery
Does it? Can they be fuel lines?
blumonster is offline   Reply With Quote
Old 05-08-2011, 05:41 PM   #4 (permalink)
Turk
Have you been able to find out what that leak is? It looks like fuel leak to me. The fluid seems to be transparent. I am dealing with fuel line leaks on my car and your answer might help me too. Thanks.
Old 05-08-2011, 06:00 PM   #5 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
There are no fuel lines in that area. That looks like transmission oil cooler line to me too. Stick your finger down there and feel it. It won't bite.
But you want that taken care of soon lest it takes your entire transmission with it.
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 05-09-2011, 07:14 PM   #6 (permalink)
View pchalpin's Photo Gallery
If it is not rusted all the way to the transmission connection, you can carefully cut the rusted part of the line out. Once that is done you have two options. Go to you nearby auto parts store and buy a new rubber transmission hose that is long enough to reach the point where you made the cut in the rusted line. The OEM rubber line is double walled to prevent chafing so buy another new bigger inside diameter hose and slide it on the other new hose to prevent chafing.
You could also cut out the rust and splice in a new piece of hose to make up the length that you cut out. You'll need a piece of hard line the use as a nipple between the OEM and new piece of hose.
You better check the lines at the radiator because those rust out too. If they are not rusted out yet, remove the surface rust with sandpaper and apply a hefty layer of grease and the won't rust any further. This should be a regular part of getting ready for winter, and they'll last forever.
pchalpin is offline   Reply With Quote
The Following User Says Thank You to pchalpin For This Useful Post:
blumonster (05-10-2011)
