Rough Idle Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2010, 08:49 AM   #1 (permalink)
View redkneck's Photo Gallery
Rough Idle Question
OK, new plugs and wires installed and new VC gasket and my CEL is gone, no more missing. I still have this rough idle that has been there since I got the car. It's not a huge issue, but annoying. It idles worse when the car is in gear, like stopping at a light than when it is in park. I got no codes pending. Any thoughts? IAC? Clean the MAF or throttle body??
redkneck is offline   Reply With Quote
Old 05-31-2010, 10:18 AM   #2 (permalink)
View glow-plug's Photo Gallery
What year is the car?
Was a compression test done?
Try water sprayed around the injectors.
glow-plug is offline   Reply With Quote
Old 06-01-2010, 07:01 AM   #3 (permalink)
98 model.
No compression test done. It's a TBI injection.
Old 06-01-2010, 11:16 AM   #4 (permalink)
Gameroom cash: $196050
View landphil's Photo Gallery
Check for vacuum leaks as well - especially around the intake manifold to the head - idle the engine, and spray the area lightly with ether or brake clean - just be carefull, and don't use so much that it will end up in the intake piping. If you have a vacuum leak it will immediatly smooth out for a second after you spray.
landphil is offline   Reply With Quote
Old 06-02-2010, 03:30 PM   #5 (permalink)
I'll do that when I get a chance. I've done it before with propane on the ford explorer I used to have, works really well. I'm starting to wonder if I have a broken/loose motor mount. The vibration is almost gone in park.
Old 06-02-2010, 11:23 PM   #6 (permalink)
Yup, an unlit torch is probably the best way actually, and good idea on the motor mount as well.
