Why does it rumble? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-30-2010, 04:06 PM   #1 (permalink)
View Ru4wheel?'s Photo Gallery
Why does it rumble?
My '02 has a rumble in the front end. It starts when I get to about 15 mph and stops around 25 mph. I also notice the steering shakes at 65mph, but is OK at all lower speeds. I had the car in for an alignment two months ago. I turned off the engine while on a side road to see if that made a difference. It didn't. What do you think is bad? Thanks.
notagain
Ru4wheel? is offline   Reply With Quote
Old 05-30-2010, 04:26 PM   #2 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
It could still be an alignment problem if you have hit some potholes since then.
You also could have lost a wheel weight, and your wheels are off balance.
SCCA First Place 10/25/09. NST
Crowbar911 is offline   Reply With Quote
Old 05-30-2010, 11:07 PM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
could be two different problems, tire balance and or a bad tire.
Old 05-31-2010, 08:43 AM   #4 (permalink)
I think you're right. After the wheel alignment I rotated the tires! The ones on the rear are older and most likely in need of a wheel balance. I'll get that done and post back the results. Thanks.
notagain
Old 06-04-2010, 08:03 PM   #5 (permalink)
I took the car in and had the front wheels balanced. Its a bit better, but not all the way gone. I did not get in onto a highway to see how it does at 65mph.
notagain
