Originally Posted by NoItIsNotACivic
i dont think we are talking about the same dude. this is Revolution Brake LLC.
wider track width would be nice but lets be serious. 5 mm on each side is not going to make a noticeable difference. the onlyconcern i have is if i can still put the 205 50's without fender rub.
the main question was, do i need to use spacers at all four corners? or just the front for clearance?
Yeah, I worded it incorrectly. I meant to say that there was a 8th gen Corolla owner that was running Wilwood caliper and a 11" rotor setup - his name was Sean2Sean. Actually had one setup specifically for the 8th gen, his car was a test case, given that some have expressed interest in a BBK. Unfortunately, demand wasn't there and I believe that "kit" has been discontinued. You can still have Wilwood custom make you a setup or pick up one from another vendor - like Revolution Brake.
As for the spacers - you have to measure the track of the car and see if the offset is appropriate. Example, if you add a 5mm spacer on just the front that has a front track 12mm wider than the rears, you would be running a total 22mm wider track at the front than the rear - almost an 1" wider in the front than the rear.
Might ask so what? Adjustments in front and rear track can have a great influence on handling of the car - both good and bad. Along with them, tire choice, wheel, suspension settings, spring rates, strut damping, etc. - all play a very crucial role in handling. Even a 5mm spacer can make a poor running car, handle great or a decent handling car yield spooky steering behavior. Not only in low speeds, nearly static cases, but under acceleration, hard braking, and cornering.
Personally, I'd apply the same offset all around to keep the ratios of the tracks pretty close. Like
PR mentioned, a 5mm spacer should not be a big deal on OEM studs. Past that - be safer to run longer studs. A 205 width tire is hit or miss for clearing the fender - depends on how much of a drop you will end up with in the end. For my 2002 - running one of the narrower 205/45-16 tires (+38mm offset), no camber adjustment, on KYB-GR2 on TRD springs (~1"-1.5" drop) it would just rub the rear fenders on bigger bumps. Fronts were fine - only rubbed on steering lock.
