what the low side ac pressure 99 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2010, 03:15 PM   #1 (permalink)
View case310350's Photo Gallery
Want to know what the low side AC pressure should be. its at 30 but ac is weak, so am i looking at a weak compressor>?
case310350 is offline   Reply With Quote
Old 05-31-2010, 04:16 PM   #2 (permalink)
Gameroom cash: $347185
View SuperRA's Photo Gallery
You might have a better chance in the 7th generation forums as we are mostly 88-92 here.
SuperRA is online now   Reply With Quote
Old 05-31-2010, 07:47 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $272321
View REN69's Photo Gallery
Thread moved to the right forum, good luck.
Old 05-31-2010, 08:39 PM   #4 (permalink)
View Quick2000's Photo Gallery
does the compressor cycle on and off a lot while the a/c is on?
Quick2000 is offline   Reply With Quote
Old 06-01-2010, 11:06 AM   #5 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
if the pressure gets to low the ac will not turn on. that is proabaly not your issue. I learned last week a good way to check the ac. go to a parts store and buy an ac thermometer for $5 . put ac on max windows up hold rpms to 2k put the thermometer in vent should go to about 40-45 if it does not go that low you should recharge it. add refrigerant until the temp stops dropping if you add to much it will start to rise.
another words don't worry so much about the pressure do the temp method.
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
Woodyg is offline   Reply With Quote
