you should have 1 hose and the MAF sensor connected to ur stock intake box, the hose should be about 1 inch in diameter n will be for ur EVAP i believe.
So just remove the stock air box, disconnect the EVAP hose and remove the black piping connecting to the throttle body. when installing should look similar to how my car is except the bend should be going up towards the firewall. so a _| shape off the throttle body. and dont forget to reconnect the EVAP hose to the new short ram. hope that helps alittle!
