Where is the O2 sensor connector? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-16-2010, 06:56 PM   #1 (permalink)
View Traderjoe's Photo Gallery
I'm trying to remove the downstream O2 sensor. I've removed the front passenger seat, but no connector! Where is it? Please advise.
Traderjoe is offline   Reply With Quote
Old 06-16-2010, 07:36 PM   #2 (permalink)
Probie
scoutsout's Avatar
View scoutsout's Photo Gallery
If I'm not mistaken, it should be there under the carpet, or ontop of the carpet, but since you said you removed the seat and you dont see it, then what I would do is cut the wire under the car and splice the new one in. The wires of the new one should match up to the wires leading into the cabin. Hope this helps.
I never said I was an expert.
scoutsout is offline   Reply With Quote
Old 06-16-2010, 09:51 PM   #3 (permalink)
Big T Dizzle fo Rizzle
BigTDogg (MA)'s Avatar
View BigTDogg (MA)'s Photo Gallery
Joe, just updated the pictures in this link here:
My O2 replacement post
No need to cut the wires, just pull from below the console and the connector will come out
My Vehicles:
2001 Toyota Corolla LE - EBC Ultimax Rotors, HPS pads, Goodridge stainless lines, K&N drop in filter, Magnaflow cat and Exhaust, KYB GR-2, Tein H-Techs
1990 Nissan 300ZX Twin Turbo - More mods than Lindsay Lohan has freckles
Last edited by BigTDogg (MA); 06-17-2010 at 07:58 AM. Reason: Updated link to post
BigTDogg (MA) is offline   Reply With Quote
Old 06-17-2010, 12:50 AM   #4 (permalink)
View phantazn's Photo Gallery
If I remember correctly you have to dig around under the foward part of the console after pulling up the carpet. There is a plastic vent tube under the seat that you will have to partially unbolt because you will be unable to move it enough otherwise to get the sensor completely free. Kind of an asshole-ish move on toyotas part to design it like that. It took me about an hour from when i first brought the jackstands up til i had it all put back together again.
phantazn is offline   Reply With Quote
Old 06-17-2010, 01:01 AM   #5 (permalink)
View Rawdop3's Photo Gallery
hey im about to replace my 02 sensors too
i was going to get a universal 4 wired one, would the 02 sensors in the 2 different spots in our corolla use the same sensor?
Rawdop3 is offline   Reply With Quote
Old 06-17-2010, 07:56 AM   #6 (permalink)
Yes, you can see the back half of it in this picture:
Infront of the airbag harness, there is an L-shaped duct you need to pop off. No bolts, just a slide fit, but it is a MOTHER EFFER to get back in to place.
As for the Rawdop3's question, universal 4 wire type sensors may work, however the mounting plate for the front sensor is different than the rear. I can say from my experiences that it is best to go with Bosch sensors, preferably OEM style. I went with a cheap no-name OEM connector unit and it failed in 6 months.
My Vehicles:
The Following User Says Thank You to BigTDogg (MA) For This Useful Post:
scoutsout (06-18-2010)
Old 06-18-2010, 02:18 PM   #7 (permalink)
Probie
scoutsout's Avatar
Awesome help BigTdogg. I've had my CEL on for-fukn-ever and just figured out its my O2 sensors. I followed the pics and right on the money
