Tensioner pulley removal.. Help!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2010, 07:59 AM   #1 (permalink)
View corolla2001's Photo Gallery
I want to replace my corolla 2001 tensioner pulley, but there is a special nut which I don't have a special socket for it. I tried to take a whole belt tensioner out, but when I unbolted one nut that I believe it bolt to the engine, it leaks out the engine coolant. I've search how to remove and install belt tensioner on All-data and Ondemand5 at work... I couldn't find it. Anyone had been replaced it before or has any idea... Help me out with it. Thank you.....
corolla2001 is offline   Reply With Quote
Old 06-17-2010, 08:57 PM   #2 (permalink)
Anyone can help me out with please!!!
Old 06-18-2010, 09:31 AM   #3 (permalink)
Gearhead
Gameroom cash: $196215
Which nut are you trying to remove? Possible you can snap a pic of the one you are removing?
Once you remove the belt - there are only two points that hold the tensioner assembly to the engine - the large center bolt (51 ft.lbs) and the nut holding the "shock" looking damper (21 ft.lbs). I don't remember any coolant that spilled out when I changed it on the Matrix, but it also has a different engine 2ZZ-GE vs your 1ZZ-FE in your 8th gen Corolla.
