Originally Posted by Bdub215
1zz-fe: VVT-I on the Top vs Non-VVt-i on the bottom. Equal Mods. i think there is a trade-off for having VVT. i mean sure they get a increased redline and nice low end torque but mine is flat till almost redline. power is more or less the same. others please weigh in.
If I read the image name correctly, the top one is some dude's 2008 and the bottom is yours.
Originally Posted by Bitter
you can see that torque on the VVT-i engine does not fall off as RPM rises as the non VVT-i engine does.
not to mention, 2 different dyno's so differences are moot.
You meant "horsepower"?
If I read the graph correctly it actually reads to me that bdub's non-VVT-i has a flatter torque curve from 4000 to 5450rpm where there is a sharper decline; whereas the 2008 torque peaks at 4600rpm and falls off more gradually. So torque wise both decline after peaking. Well what's the definition of "peaking" anyway?
HP wise yes VVT-i peaks much closer to redline so you don't see the decline. But for the kind of driving a Corolla is meant for, I want HP and torque earlier, plus there isn't much difference - they're within 2hp of each other for the rev range that matters - 2500-3500rpm. If not for the inexplicable torque dip of the non-VVT-i between 2500-3800rpm I'd say non-VVT-i does better.
