injector resistance too high? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2010, 01:47 PM   #1 (permalink)
View romerodell's Photo Gallery
i know that the acceptable range of the injectors are 13 to 15 ohms but i am getting 17 ohms on all 4 of my injectors. I recently got a p0300 code but once i cleaned my maf sensor, the cel went away. i checked the plugs and they look fine. Is 17 ohms too high ?
romerodell is offline   Reply With Quote
Old 06-19-2010, 04:21 PM   #2 (permalink)
Toyota Tech in training!
View Downhillzze110's Photo Gallery
what temp did you test your injectors at?
my Haynes says they should have around 13.4-14.2 Ohms at 68 deg. F
slightly higher resistance is to be expected at higher temps, take your injectors inside, let them cool down and try again, see what that gives you.
also have you performed a compression and leakdown test? bad compression or a burnt valve may be the cause. also you may want to check to make sure your Crank Position sensor is reading and working correctly.
oh sorry, first things first i s'pose... take your injectors out, let them get to 68 (or around there) and retest them
before you ask a 'how do i...' question answer this for me. do you own a repair manual for it? have you searched the forum for a similar issue?
SEARCH THE FORUM BEFORE YOU POST!
Downhillzze110 is offline   Reply With Quote
Old 06-21-2010, 10:21 PM   #3 (permalink)
View glow-plug's Photo Gallery
That value would depend on the accuracy of the ohm meter could try another meter.
Just a thought.
glow-plug is offline   Reply With Quote
