2000 Corolla P0171, P0304, very sluggish (long post)
I have continued problems with very sluggish acceleration with my 2000 Corolla CE, having 120,000 miles. I have more time than money right now so I tried to fix it myself, thinking that this would be simple, maybe plugs or whatever. Right now it is difficult to even climb a hill unless my engine has been running for some time. I will throw in some added content below to help anyone else having my problems who is as clueless as I am.
I have to spray starter fluid in the air intake filter to get it to start some times. eventually it runs great on the highway.
0. The OBDII thing read P0304 and P0300 and P0171, meaning misfire on 4, general misfire, and lean mixture. Sometimes also P0303.
1. I replaced the spark plugs with new approved plugs. The 4 plugs are under the easily removable engine cover in 4 deep wells under the 4 coil pads which look llike 4 plastic square pieces. There are no spark plug wires.
2. I inspected the fuel pump by removing it from under the rear seat. The plastic fuel pump assembly is maybe 6 inches in diameter and 8 inches tall. Inside is the fuel pump which is metallic and twice the size of a shotgun shell. The fuel filter looks like a horseshoe from the top, and is the size of a small hand curled around the fuel pump viewed from the side. There is an external strainer sock as well. I blew air through the fuel filter and some dirty spray came out.
Note: If you buy a fuel pump from NAPA/whoever, you only get the fuel pump, not the assembly, and not the fuel filter. I did find a separate fuel filter on the Internet, but it was hard to find.
3. I later tested the fuel pressure and it was OK. Maybe 27 as I recall. The fuel pump relay is directly behind the pivoting change compartment near the driver's left knee. It is on the lower left when looking toward the drivers side quarter panel from under the dash board.
4. A shade tree mechanic looked at it, and suspected a vacuum leak, but could not find one, but did not test the vacuum. He replaced the air intake manifold at my request and manually cleaned out the throttle body assembly very well. He swapped around the coil pads but the misfire problems stayed with cyliner 4, sometimes also 3. I had cleaned the mass flow sensor with approved stuff.
He suggested using lots of Sea Foam and some Marvel mystery oil.
The Sea Foam seems to have helped and it ran better, but I suspect I was treating the sympton, not the cause.
5. I replaced the oxygen sensor that is upstream of the catalytic converter. This was hellish until I learned to lean over the engine from the passenger side and use my LEFT hand.
Also, put in new EGR and PCV valve.
It is now as bad as ever.
What to do? I would like to fix it myself rather than admit to failure, wasting money, and being a moron.
Will a Toyota dealer plug in some superdiagnostic and find the problem in no time? How much would this cost to diagnose?
P.S. I really hate the Haynes manual for this car and year.
Reason: spelling errors.
