P0420 Solution - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2010, 08:01 AM   #1 (permalink)
View amisso41's Photo Gallery
P0420 Solution
I have a 2000 corolla LE with 180,000 miles. I had the CAT replaced with an aftermarket Magnaflow (welded in) that the shop welded in about 15,000 miles ago and CEL came on after about 5,000 miles with P0420. Took it back to the shop said the cat was fine and they also verified both O2 sensors were working correctly. I had no noticeable problems with the car and MPG and operation was still normal. Needed to get it inspected (MA) and was told the only option for it to pass was to pay $1500 at the dealer for an official toyota CAT.
I found this fix on a a different forum involving a spark plug defouler, drilling it out, and attaching it the rear O2 sensor. Rented an O2 sensor wrench from autozone and was even able to get the rear sensor off without lifting up the car at all (with a hammer and lots of PV Blaster). Link to photo instructional and part below.
http://www.k-series.com/forum/showth...hanical-02-Sim
Amazon Amazon
http://www.autozone.com/autozone/cat...&brandName=OEM
2,000 miles later I have my inspection sticker, no CEL, and no drop in MPG or performance. Hope this helps.
amisso41 is offline   Reply With Quote
Old 08-31-2011, 06:01 PM   #2 (permalink)
View joe68's Photo Gallery
What spark plug non-fouler did you use? brand? model? size?
joe68 is offline   Reply With Quote
Old 08-31-2011, 09:03 PM   #3 (permalink)
I used a Dorman model # 42009
Amazon Amazon
Old 09-01-2011, 10:49 AM   #4 (permalink)
View Quick2000's Photo Gallery
That's how I fixed mine as well. Works flawlessly.
Quick2000 is offline   Reply With Quote
Old 09-04-2011, 04:20 PM   #5 (permalink)
View kitzmiller88's Photo Gallery
true?
doesent this trick cause the ecu to run leaner? ive heard you have to use a octane booster to even it out? is this true
kitzmiller88 is offline   Reply With Quote
Old 09-04-2011, 05:25 PM   #6 (permalink)
Nope, the post cat o2 sensor is for emissions and detects if the catalytic converter is functioning properly. The upstream o2 sensor is the one the ecm uses to adjust air/fuel ratios.
Old 09-08-2011, 11:52 AM   #7 (permalink)
mital917's Avatar
View mital917's Photo Gallery
[QUOTE=amisso41;3238352]I have a 2000 corolla LE with 180,000 miles. I had the CAT replaced with an aftermarket Magnaflow (welded in) that the shop welded in about 15,000 miles ago and CEL came on after about 5,000 miles with P0420. Took it back to the shop said the cat was fine and they also verified both O2 sensors were working correctly. I had no noticeable problems with the car and MPG and operation was still normal. Needed to get it inspected (MA) and was told the only option for it to pass was to pay $1500 at the dealer for an official toyota CAT.
http://www.amazon.com/Dorman-HELP-42009-Spark-Non-Fouler/dp/B000CO91FY/ref=sr_1_1?ie=UTF8&s=automotive&qid=1277297074&sr=8-1 http://www.amazon.com/Dorman-HELP-42009-Spark-Non-Fouler/dp/B000CO91FY/ref=sr_1_1?ie=UTF8&s=automotive&qid=1277297074&sr=8-1
what size drill bit did you use?
mital917 is offline   Reply With Quote
Old 09-09-2011, 07:48 PM   #8 (permalink)
105
View 105's Photo Gallery
Did you drill it all the way through with a half inch bit or just enough so the 02 would fit?
Your instruction link isn't working for me.
1998 Toyota Corolla VE (A3 --> A4 swap completed 9-30-10)
105 is offline   Reply With Quote
Old 09-16-2011, 11:24 AM   #9 (permalink)
105
Well so far I've had no trouble (100 miles). I drilled the non-fouler completely out with a 1/2" drill bit but not all the way through. Just enough to where it started to stretch the hole open at the end of the non-fouler. This way it will let very little fumes reach the 02.
I used vice grips and my foot to hold the non-fouler in place on the floor while I drilled it little by little.
I did this because my cat was starting to fail so I replaced it with a straight pipe.
Old 09-18-2011, 12:22 PM   #10 (permalink)
mital917's Avatar
i drill out the non fouler with a 1/2in bit and i have a high flow flowmaster cat and i still have the cel on any suggestions?
Old 09-18-2011, 01:55 PM   #11 (permalink)
Did you reset the ecm? And did you drill all the way through the defouler? or just enough so the O2 sensor could fit in?
Old 09-18-2011, 02:03 PM   #12 (permalink)
mital917's Avatar
i did reset the ecm n i drilled all the way through the fouler
Old 09-18-2011, 02:50 PM   #13 (permalink)
That's why- you're not supposed to drill all the way through. You're supposed to leave the hole at the end of the defouler small.
Old 09-19-2011, 07:33 AM   #14 (permalink)
105
Since you did drill it all the way through, just screw the other nonfouler that came in the pack onto the end of the drilled one. I've seen it done this way too.
Old 10-04-2011, 09:34 PM   #15 (permalink)
View militarydave's Photo Gallery
my 1999 CE has 177xxx miles on it. the P0420 code came on earlier today. I re-set (cleared) the code with an OBDII code scanner (a good one, not the el cheapo autozone kind).
so far so good. code hasn't come back. If I dont do this fouler/drilling thing, would I have any adverse effects on the car, besides the state inspection?
thoughts?
militarydave is offline   Reply With Quote
