Originally Posted by farshidrx
My 98 corolla has this hiccup when the RPM is below 3000. It fails to put out power below this range and when it goes past 3k rpm the issue fades away and power is normal. The check engine light started flashing and then stayed lit. I took the car and had the code read by Autozone. It said cylinder 2 misfire. The wires and plugs were replaced, and the only thing that Im thinking is coil pack or injectors...remember that I have power above 3k but constant misfire below 3k..
What could it be? I want to fix this myself but cant afford to buy a whole bunch of parts. Where should I start?
When I had this issue, I swapped cyl2 coil pack with cyl3 coil pack so see if the check engine code moved cylinders. (Be careful to keep the right firing order.)
When that doesn't work, Swap injector 2 with injector 3. See if the code moves cylinders.
When that doesn't work, do a compression test on Cylinder 2. If your car is like mine, you'll find no compression and a burnt out valve. Pray its not that.
