DIY Front Brakes Corolla 98 - 02 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2010, 03:19 PM   #1 (permalink)
CorollaCarClub.proboards.
RinconRolla98's Avatar
View RinconRolla98's Photo Gallery
Exclamation DIY Front Brakes Corolla 98 - 02
This is a DIY for changing your front brakes in a corolla 98 - 02 .
First you just slightly crack your lug nuts and then you find a secure spot to jack up the corolla in my photo I used the front frame so that I can raise both sides at once . Then you place jack stands in a secure area lower the corolla on the jack stands then you can remove the rest of your front tires .
Once you have the tires off then you can use your rachet with a 14mm socket and start removing the bolts that hold down the brake caliper .
Then with a flat head screw drive you gently pry back the caliper .
Then you can spread your front brake pads apart . You can use a screw driver here to of needed .
Some don't but I personally put on some brake quiet on the back of the front pads . This is optional but I love my corolla so I use it . Then you let this set for a few seconds .
While your letting your pads set then you can just slightly crack open the top of your brake fluid cap then with the proper tool you push back the piston in the caliper . Once that is done then you put back your cap .
Then you put back your pads and brake caliper the same way you removed them and your done .
Then when you are done you tighten up the lug nuts and lower your corolla , Make sure your brake fluid cap is back on , Before you start the car pump your brakes until the brake pedal comes up . Some cars do not need top be blead but if you opened the line or your fluid is nasty it is recommended that you bleed your brakes . And with not alot of time there you have your front brakes changed .
More DIY http://rinconrolla98.blogspot.com/
RinconRolla98 is offline   Reply With Quote
Old 06-26-2010, 04:55 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
great how-to except you should open the brake bleeder when pushing the pistons back. forcing fluid backwards through the system can be bad on the master, also you're pushing out the old nasty fluid and then bleeding in some fresh fluid which is always good.
Old 06-27-2010, 10:23 PM   #3 (permalink)
View Mashettiwar's Photo Gallery
I didn't end up bleeding the brakes at all...is that a bad thing?
Mashettiwar is offline   Reply With Quote
Old 06-28-2010, 01:08 AM   #4 (permalink)
Beaterolla's Avatar
View Beaterolla's Photo Gallery
I never bleed them either as long as the pedal has a good feel.
Never a problem.
I prefer to be judged by what I do and not by what I own.
Beaterolla is offline   Reply With Quote
Old 06-28-2010, 07:12 AM   #5 (permalink)
Bitter's Avatar
Never a problem.
brake fluid absorbs water, this makes it turn corrosive and lowers its boiling point. it should be changed about every 2 years.
Old 06-28-2010, 09:04 AM   #6 (permalink)
DjiNN's Avatar
View DjiNN's Photo Gallery
Are those grooves in your rotor? if it is then I suggest you change your rotor out when possible.
Subaru Impreza 2.5i Premium Satin White
DjiNN is offline   Reply With Quote
Old 04-30-2012, 01:14 PM   #7 (permalink)
View tad2much's Photo Gallery
great write-up. any link to how to bleed the brake fluid?
the thread here discusses the proper order, though not quite definitively. I'd appreciate a bit more step by step if anyone could help out.
thanks!
tad2much is offline   Reply With Quote
