Originally Posted by scoutsout
The only thing I can think of is your rotors are starting to warp. Since it happens only braking. The gravity pull is stronger when you're going downhill, hence the vibration only happening when going downhil. I know someone that sells drilled/slotted rotors with ceramic pads for $80 a set. Let me know if you want to hit him up for a new set.
I was thinking the rotors. Havent measured them yet, but the OEM rotors lasted quite some time, 75K. I still have those. Maybe I will get them turned and put new pads on and see.
I am still doing struts too.
