Originally Posted by ilovecorollale
I got this obx cat converter from my brother who used to own a 7th corolla
and this cat is still new unused...i was wondering if it will fit onto the 8th corolla?
And i also just got these two rear dropzone shocks from my brother too and unused also.I know their suspensions are the same or so but not sure about the cat converter.
obx does not make a legitimate catalytic converter. the "cat" you have is a resonated test pipe. it can be made to work, but will not bolt in because our cats are welded in place in the b pipe. most muffler shops will not install your "cat" because it is illegal. also once installed it will throw a check engine light for having a bad cat converter.
the shocks will work. the test pipe will not unless you find someone to cut out the stock cat and weld in the new test pipe.
