disabling DRL
I was wondering how to disable the DRL for good because I just installed HID and they flicker when the DRL are running. I tried pulling the dome and DRL fuses along with the DRL relay under the hood with no luck. I pull the hand break up one click to turn them off but it only works when you remember to do it right the first time. I have the TSB and know where the DRL module is too. I know I have to go to connector D3 and pin # 23. It’s a 01 corolla (Canadian). I’m unsure what wire to remove and I do not want to jump to conclusion and have something messed up. My car doesn’t have Twilight Sentinel.
