Change strut mounts or sway bar links? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2010, 10:01 PM   #1 (permalink)
View thisoneroller's Photo Gallery
I have a 01 corolla with 152000 miles in it and I just changed all four struts. Now, everytime I go on bumps, Im hearing clunking noises. My mechanic told me that I have to change my front strut mounts and my rear strut mounts. Another mechanic told me, it could be the front sway bar links. I checked the front sway bar links to see if its loose but there not. However, I do see lots of rust. Any suggestions? I'll try to post pictures tomorrow.
thisoneroller is offline   Reply With Quote
Old 07-01-2010, 07:19 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
do the links and bar bushings first since they're easier and at that many miles i guarantee worn out of they're original. front and rear!
the noise started when you swapped struts or was there before? check balljoints and tierods as well. ball joints and tierods will seem tight with the wheels on the ground, same for the sway bar links and bushings.
Old 07-01-2010, 09:33 PM   #3 (permalink)
Probie
scoutsout's Avatar
View scoutsout's Photo Gallery
agreed. I would do the same, especially if on a budget.
I never said I was an expert.
scoutsout is offline   Reply With Quote
Old 07-02-2010, 11:45 PM   #4 (permalink)
i fixed the problem. I replaced all four sway bar links, drove the car, boom no noise. Thanks for all of your help
Old 07-05-2010, 07:33 PM   #5 (permalink)
Bitter's Avatar
the sway bar bushings are probably also worn, reach under and the bar should be totally solid to the car. if not, replace the bushings. they're cheap and easy.
Old 07-10-2010, 01:30 AM   #6 (permalink)
View nukleuz's Photo Gallery
I had the same noise but even after I changed my struts and strut mounts the noise was still there. So I installed new sway bar links and bushings and the noise went away and suspension became so quiet and comfortable. I don't hear that annoying noise when going over bumps anymore.
nukleuz is offline   Reply With Quote
Old 07-10-2010, 02:08 PM   #7 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
Mine are old and worn both bushings and end links but still no noise from it going over bumps.Should i change it whenever i start hearing noises?
ilovecorollale is offline   Reply With Quote
Old 07-10-2010, 10:15 PM   #8 (permalink)
Bitter's Avatar
change it out, you'll feel a difference in handling.
