positive 12 volt source when engine run - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2010, 12:25 PM   #1 (permalink)
yanlapanic's Avatar
View yanlapanic's Photo Gallery
All is in the tittle , I search a place where there is 12 volt power source but only when engine is running , It only to place a relay to power something .
A picture would be nice If you want
Thanks you!
sorry for my bad english , Im frenchies !
corolla 1999 ...
yanlapanic is offline   Reply With Quote
Old 07-01-2010, 02:47 PM   #2 (permalink)
View glow-plug's Photo Gallery
Do you want power when the key is in the postion or only when the engine is running?
glow-plug is offline   Reply With Quote
Old 07-01-2010, 04:19 PM   #3 (permalink)
yanlapanic's Avatar
Only when engine is running ,
corolla 1999 ...
Old 07-01-2010, 05:16 PM   #4 (permalink)
You going to have to build some kind of logic circuit if you only want power when running.
Old 07-01-2010, 05:18 PM   #5 (permalink)
yanlapanic's Avatar
Im sure I can find a 12 volt source which will turn on my circuit
what do you think about fuel pump?
corolla 1999 ...
Old 07-01-2010, 10:09 PM   #6 (permalink)
DjiNN's Avatar
View DjiNN's Photo Gallery
Is the device going to be in or outside the car.
Subaru Impreza 2.5i Premium Satin White
DjiNN is offline   Reply With Quote
Old 07-01-2010, 11:04 PM   #7 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
you may need to use a ground trigger on the relay and find something that the PCM grounds only when the engine is spinning.
Old 07-02-2010, 03:28 PM   #8 (permalink)
yanlapanic's Avatar
Onboard ,
I dont understand what mean pcm ground and everything
corolla 1999 ...
Old 07-02-2010, 07:14 PM   #9 (permalink)
Bitter's Avatar
then you should read a good auto electronics text book before embarking on this venture, not trying to be an ass...just trying to save you some headaches. if you understand what you're doing vs just following directions then you'll be able solve your own problems instead of waiting for answers.
Old 07-02-2010, 07:36 PM   #10 (permalink)
yanlapanic's Avatar
I think i'll put the relay after the relay of the hid , It seem that my hid start only when I start running ... and they stop when I close the engine (on DRL) .
Anyways It would be ok for the moment like this .
corolla 1999 ...
