no headlights and engine stalling - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2010, 01:11 AM   #1 (permalink)
View jess the tech's Photo Gallery
i have read the post of the DRL bad ground but i am wondering if this can also be causing my brake light coming on when the fans kick on and the engine stalling also when either i put on a turn signal or turn on my a/c. The car was sitting for a while and i got a good deal on it knowing it had these electrical problems . Wondering if anybody else has had this problem. I have checked to see if i was getting a/c current out of alternator but it checked out fine. I can hear sometimes multiple relay buzzing or clicking at times , but like i said it seems as soon as fans or turn signal or headlights turned on , engine stalls. Any help would greatly be appreciated
jess the tech is offline   Reply With Quote
Old 07-10-2010, 01:15 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
it sounds like you have an issue with a bad ground and the engine is pulling ground from somewhere else.
Old 07-10-2010, 01:20 AM   #3 (permalink)
I will check for any bad grounds, thanks for the tip
Old 07-10-2010, 11:02 AM   #4 (permalink)
update i grounded my DRL relay ground wire like the previous post said and it all working fine except my headlights stay on after i shut off the car. Can anyone tell me if they had the same problem?
