I've looked over some specs that I have for Toyota MAP sensors, but wiring colors doesn't line up. I'd suggest taking a high impedance voltmeter and probing the connection side. Should be able to find which one is ground and which one has a constant voltage (source voltage). The leftover connection is the pressure signal to ECM - you can verify this with a change in pressure (changes in pressure changes the voltage output of the powered sensor).
