I just went through the entire engine and anything else I could get my stethoscope onto. The noise is a whistling, but I think it is a chain type noise. Ever heard a VW bugs chain noise. Its fast enough to be a annoying whine.
I touched the alternator, timing chain area, pulleys, injectors, valve cover, block, exhaust all sensors, and nothing changes. The whistling noise on mine is on/off intermittently, mostly on.
Ever seen a belt go through harmonics, as it will vibrate, then steady up then vibrate again. Thats the same thing happening within the engine.
Can it be the VVti system?
