so about the water pump from a 2zz, it is interchangeable meaning just bolt onto 1zz but only the pulley is lager, requiring a larger belt to run like 2" more than then the stock 1zz belt, but how will i get the belt to only be 2" larger or the belt from a 2zz will do it?
There's alot of 2zz water pump on ebay...as long as it is a 2zz water pump then it'll work?What really is the differ between a 1zz and 2zz water pump besides saying it is better and efficient...i mean like the parts in differ or materials made of.
Also how about the light weight alternator pulley from monkey wrench...it will fit both 1zz and 2zz since it should be the same size as the oem alternator pulley????
