brake light pblm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-18-2010, 01:35 PM   #1 (permalink)
View njcamry's Photo Gallery
brake light pblm
hey guys..got a 99 corolla and jus a quick q, i just realized all my brake lights are out (only back 1's) including the top linear 1 on the windshield, i changed the bulb, but nothing.. these are the ones located on the trunk itself not on the bumper..u press the brakes and get no response!
the reverse lights work, the turn signals work, and the outside rear ones work too (that go on with the headlights)..any ideas what it may be? thanx for the inputs
njcamry is offline   Reply With Quote
Old 07-18-2010, 02:32 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Check your brake light switch located at the top of your brake pedal.
The Jedi Speeder at CarDomain
Old 07-19-2010, 12:36 AM   #3 (permalink)
ok thanx, ill look at that, if not it, any other ideas?
Old 07-19-2010, 10:29 AM   #4 (permalink)
Gameroom cash: $105620
View wylee's Photo Gallery
Is the fuse blown?
2010 Corolla S 5 speed. It's GONE!
2007 Corolla CE Auto
2010 Aveo5 - good CHEAP car so far
wylee is offline   Reply With Quote
Old 07-20-2010, 02:33 AM   #5 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
If it's anything like my 93' Corolla then there will be a 15-amp fuse in the engine compartment that services the stop lights. The other lights such as the indicators etc are operated by a separate fuse. That would be the first place I'd check. The location of the fuse may be slightly different to mine, but it should be labelled on the fuse cover and/or in the factory owner's manual.
Old 07-20-2010, 04:33 PM   #6 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Fuse # 8
Inspect mentioned brake switch near pedal, constant voltage on one side, switched voltage on the other side.
CraigW is offline   Reply With Quote
