2002 corolla camber bolt replacement question
Hello, I have a 2002 toyota corolla. I was having a problem with the vehicle pulling to the passengers side. I took it to get aligned at firestone, where I have a lifetime alignment program.
I had another mechanic recently replace the struts because they were shot. I had the car aligned before and after the strut replacement.
However, after the strut replacement the car was going to the right slightly and it got worse over the course of 3 months.
At first it wasnt so bad, but then I took it to get an oil change so I had them realign it and they said the front and rear passenger cam bolts needed to be replaced. Im thinking either them or the other mechanic might have broken them.
But anyways, I called Toyota to get a price quote on the parts, because firestone wanted $130 for the front and $130 for the rear cam bolt replacement. I normally just pay to have it done, but Im thining this is a fairly easy thing to do and I am pretty familiar with vehicle tear downs.
So I call Toyota, they tell me there are 4 different sizes and that I need to measure the bolt to find out which one I need. They also told me the rear has no cam bolts. They said the sizes were 12.4, 13.3, 13.9 and 15 (im assuming cm). and they said they were about $7.13 each.
So I wanted to ask here to see if anyone could guide me a little bit.I know advance auto parts sells aftermarket kits, would it be fine to use one of those? They do sell rear cam bolts so ima ssuming the dealer didnt know what he was talking about. Also do I need to change both in the front if I need to change just one? Or is it ok to have a stock cam bolt on one side and an aftermarket on the other?
Also, would it be ok to change the bolts at home and drive it about 5 miles to the alignment place, or would it be a better idea to just swap the bolt in the parking lot? Aside from the bolt maybe being seized up, I see no problem doing this and should be a quick job.
Any guidance would be appreciated. I have never changed a cam bolt before, but I do have the hanes for the car and prety sure I could follow the steps with no problems, I have no torque wrench though, so I would need to get one.
